All files / dist/commands init.js
59.32% Statements 35/59
60% Branches 12/20
57.14% Functions 4/7
58.62% Lines 34/58
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 1341x           1x 1x   1x 1x 1x 1x 1x 1x 1x 1x 1x   1x                                         1x 4x           2x 2x     2x                                                         1x 8x       8x 8x   8x 8x             8x 8x       8x 8x 8x 8x     8x 7x     8x 8x
module.exports.usage = `Set up a new service
Usage: api init
Asks a series of questions which will be used to generate a new service in the current directory`;
module.exports.category = 'basic';
module.exports.weight = 1;
require('colors');
const fs = require('fs');
const path = require('path');
const semver = require('semver');
const utils = require('../utils/utils');
const validName = require('validate-npm-package-name');
const createEnquirer = require('../lib/enquirer');
const packageJson = require('../lib/package-json');
const exit = require('../utils/exit');
module.exports.run = () => {
  const enquirer = createEnquirer();
  console.log('');
  console.log('Let\'s create your new API!'.cyan);
  console.log('');
  console.log('ReadMe Build is a really, really simple way to create awesome APIs.');
  console.log(`Learn more at ${'https://readme.build'.underline}`.grey);
  console.log('');
  let existingPackageJson;
  try {
    existingPackageJson = require(path.join(process.cwd(), 'package.json'));
  } catch (e) {
    existingPackageJson = {};
  return enquirer.ask(module.exports.questions(existingPackageJson)).then(module.exports.init);
module.exports.questions = existingPackageJson => {
  return [{
    type: 'input',
    message: 'Name your service',
    default: existingPackageJson.name || path.basename(process.cwd()).toLowerCase(),
    validate: input => {
      const valid = validName(input);
      Eif (!valid.validForNewPackages) {
        // npms package used to allow this, so the warning
        // isn't very good for our case
        return (valid.errors || valid.warnings.map(warning => warning.replace('can no longer', 'cannot'))).join('\n');
      return true;
    type: 'input',
    message: 'Version number',
    default: existingPackageJson.version || '0.0.1',
    validate: v => {
      if (!semver.valid(v)) {
        return `${v} is not a valid semver version`;
      return true;
    type: 'input',
    message: 'What is the name of your first endpoint?',
    default: 'helloWorld'
    type: 'list',
    message: 'It seems like there are already files here. Do you want to create a new directory?',
    choices: ['yes', 'no', 'abort'],
    when: () => fs.readdirSync(process.cwd()).length
module.exports.init = answers => {
  Iif (answers.continue === 'abort') {
    exit(0);
  const data = fs.readFileSync(path.join(__dirname, '../utils/stub.js'), 'utf8');
  const stub = data.replace(/<<action>>/g, answers.action);
  let chdirMessage = '';
  Iif (answers.continue === 'yes') {
    const newPath = `./${answers.name}`;
    fs.mkdirSync(newPath);
    process.chdir(newPath);
    chdirMessage = `\n  ${'$'.grey} ${'cd'.yellow} ${answers.name.yellow}\n`;
  fs.mkdirSync('./endpoints');
  fs.writeFileSync(`./endpoints/${answers.action}.js`, stub);
  // Need to initialise the package.json object down here
  // so that process.cwd() is different in tests
  const pjson = packageJson();
  pjson.set('name', answers.name);
  pjson.set('version', answers.version);
  pjson.write();
  // Only add a readme if one does not exist
  if (!fs.existsSync('readme.md')) {
    fs.writeFileSync('readme.md', `# ${answers.name}\n\nWelcome to ${answers.name}\n`);
  Eif (process.env.NODE_ENV === 'testing') {
    return undefined;
  const filename = `./endpoints/${answers.action}.js`;
  const name = (utils.getGitConfig('user.name') || 'Julie').split(' ')[0];
  return console.log(`\n${'============================='.grey}
${'Great! We\'ve set up your api!'.green}
1. Try running it locally first:
  ${chdirMessage}
  ${'$'.grey} ${`api local ${answers.action} name=${name}`.yellow}
2. Edit ${filename.cyan} and build your API!
3. When you're ready to release, run:
  ${'$'.grey} ${'api deploy'.yellow}
