All files / dist/commands deploy.js
47.15% Statements 58/123
63.16% Branches 24/38
42.86% Functions 9/21
47.06% Lines 56/119
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 2401x       1x   1x   1x 1x 1x 1x 1x 1x 1x 1x 1x 1x 1x   1x 1x 1x     4x 4x     4x   4x 2x 2x   2x       2x   2x   1x       1x           1x                                 5x 1x     5x 1x         5x 2x 3x 2x       1x   1x        1x 9x   9x   9x         9x             2x   3x 1x     2x 1x   1x         9x 6x             6x       2x         9x     1x
module.exports.usage = `Deploys a service to build
Usage: api deploy`;
module.exports.weight = 2;
module.exports.category = 'basic';
const validName = require('validate-npm-package-name');
const archiver = require('archiver');
const semver = require('semver');
const fs = require('fs');
const request = require('../lib/request');
const buildDocs = require('build-docs');
const path = require('path');
const createEnquirer = require('../lib/enquirer');
const ProgressBar = require('progress');
const utils = require('../utils/utils');
const exit = require('../utils/exit');
const readmePath = path.join(process.cwd(), 'readme.md');
const zipDir = path.join(utils.cacheDir(), 'output.zip');
const enquirer = createEnquirer();
function fetchDeployedVersion(packageJson) {
  let deployed = { versions: [] };
  let hasDeployedVersion = false;
  // Pass in team as a query string if this is a private package
  const qs = packageJson.get('team') ? { team: packageJson.get('team') } : null;
  return request.get(`/services/${packageJson.get('name')}`, { defaultErrorHandler: false, qs }).then(response => {
    deployed = JSON.parse(response);
    hasDeployedVersion = deployed.versions.some(version => version.version === packageJson.get('version'));
    Iif (hasDeployedVersion) {
      console.log(`\nv${packageJson.get('version')} has already been deployed.`.red);
    return { deployed, hasDeployedVersion };
  }).catch(err => {
    if (err && err.statusCode !== 404) throw err;
module.exports.fetchDeployedVersion = fetchDeployedVersion;
function fetchTeams() {
  return request.get('/teams').then(response => JSON.parse(response));
module.exports.run = () => {
  const packageJson = require('../lib/package-json')();
  const valid = validName(packageJson.get('name'));
  if (!valid.validForNewPackages) {
    console.log('Invalid Package Name'.red);
    return undefined;
  return Promise.all([fetchDeployedVersion(packageJson), fetchTeams()]).then(results => {
    const { deployed, hasDeployedVersion } = results[0];
    const teams = results[1];
    enquirer.ask(module.exports.questions(deployed.versions, hasDeployedVersion, teams)).then(module.exports.deploy.bind(null, packageJson, teams[0]));
  }).catch(request.errorHandler);
function prepareDeploy(packageJson, defaultTeam, answers) {
  if (answers.private && answers.private.includes('private')) {
    packageJson.set('name', `@${answers.team || defaultTeam.name}/${packageJson.get('name')}`);
  if (answers.version) {
    packageJson.set('version', answers.version);
  // If there is a team answer, then this must be a newly deployed
  // service, so persist it to the package.json
  if (answers.team) {
    packageJson.set('team', answers.team, { build: true });
  } else if (!packageJson.has('team', { build: true })) {
    packageJson.set('team', defaultTeam.name, { build: true });
module.exports.prepareDeploy = prepareDeploy;
module.exports.deploy = (packageJson, defaultTeam, answers) => {
  prepareDeploy(packageJson, defaultTeam, answers);
  const output = fs.createWriteStream(zipDir);
  const archive = archiver('zip', { store: true });
  console.log(`Deploying version: ${packageJson.get('version')}`.green);
  console.log('Converting to travel size...');
  const readme = utils.fileExists(readmePath) ? fs.readFileSync(readmePath, 'utf8') : false;
  if (!readme) {
    console.warn('No readme.md file is present'.yellow);
  // listen for all archive data to be written
  output.on('close', () => {
    console.log('Flying up to the cloud...');
    const req = request.post('/services/', { resolveWithFullResponse: true, sendRequest: false });
    const form = req.form();
    let docs;
    try {
      docs = buildDocs.parseDirectory(path.join(process.cwd(), 'endpoints'));
    } catch (e) {
      console.error(`\nError generating documentation: ${e.message.red}\n`);
      exit(1);
    // Check if user edited the documentation
    // We want to force people to at least delete the stub
    const unchangedDocs = utils.getUnchangedDocs(docs);
    if (unchangedDocs.length) {
      console.error('\nThe comments in your endpoints are important!'.red);
      console.error('\nThey are used to generate documentation and inform Build about your code.\n\nEdit the comments in the following files to deploy:\n');
      for (const doc of unchangedDocs) {
        console.error(`endpoints/${doc}.js\n`.green);
      exit(1);
    form.append('version', packageJson.get('version'));
    form.append('name', packageJson.get('name'));
    form.append('docs', JSON.stringify(docs));
    form.append('readme', readme || '');
    form.append('team', packageJson.get('team'));
    form.append('service', fs.createReadStream(zipDir), {
      filename: `${packageJson.get('name')}.zip`,
      contentType: 'application/zip'
    let progressBar;
    // get upload size
    form.getLength((err, size) => {
      progressBar = new ProgressBar('Uploading [:bar] :percent :etas', {
        total: size,
        complete: '=',
        incomplete: ' ',
        width: 50
    // calculate uploaded size chunk by chunk
    form.on('data', data => {
      progressBar.tick(data.length);
    req.then(res => {
      console.log('Cleaning up...');
      fs.unlinkSync(zipDir);
      console.log('Persisting changes back to package.json');
      packageJson.write();
      const url = res.headers.location.replace(/www\./, '');
      console.log(`\nšŸŽ‰  ${'Success!'.green} Your API is deployed!`);
      console.log(`\nSee the documentation: ${url.cyan.underline}`);
  archive.on('error', err => {
    console.error('Error during upload', err);
  archive.pipe(output);
  const handler = path.join(__dirname, '../utils/handler.js');
  const handlerUtils = path.join(__dirname, '../utils/handler-utils.js');
  archive.append(fs.createReadStream(handler), { name: 'handler.js' });
  archive.append(fs.createReadStream(handlerUtils), { name: 'handler-utils.js' });
  archive.append(`module.exports = ${JSON.stringify(utils.buildErrors())}`, { name: '_errors.js' });
  archive.glob('**');
  archive.finalize();
module.exports.questions = (versions, hasDeployedVersion, teams) => {
  let newVersion;
  try {
    // Increment minor if it ends with a 0, or patch if there's already a patch
    newVersion = semver.inc(packageJson.get('version'), packageJson.get('version').split('.')[2] === '0' ? 'minor' : 'patch');
  } catch (e) {
    // Carry on!
  const questions = [{
    type: 'input',
    message: 'What version do you want to deploy?',
    default: newVersion,
    // Ask what version to deploy if this version has already
    // been deployed once
    when: () => hasDeployedVersion,
    validate: v => {
      if (!semver.valid(v)) {
        return `${v} is not a valid semver version`;
      if (versions.find(version => version === v)) {
        return `Version ${v} has already been deployed.`;
      return true;
  // Checking for `build.team` and only asking if unset
    questions.push({
      type: 'list',
      message: 'Is your service public or private?',
      choices: module.exports.privateChoices
    questions.push({
      type: 'list',
      message: 'Which team should this service be deployed to?',
      choices: teams.map(t => t.name),
      when: () => teams.length > 1
  return questions;
module.exports.privateChoices = ['public (free)', 'private (requires paid plan)'];
