module.exports.usage = `Update the used version of this service
Usage: api update <service> [<version>] [--team <team>]
The version is optional, and will by default update you to the latest.
--team is used to designate which team you would like to update
module.exports.weight = 5;
module.exports.category = 'utility';
require('colors');
const createEnquirer = require('../lib/enquirer');
const request = require('../lib/request');
const console = require('../utils/console');
const { prefixName } = require('../lib/invoke');
const enquirer = createEnquirer();
module.exports.run = (args, opts) => {
if (!args[1]) throw new Error('Please include a service you want to upgrade!');
if (!args[2]) console.log('No version specified, updating to latest');
return request.put(`/services/${prefixName(args[1])}/update`, {
json: { version: args[2], team: opts.team },
defaultErrorHandler: false
}).then(s => {
console.log(`${args[1]} updated to version ${s.version.green}`);
}).catch(e => {
if (e.error.code === 'TeamSelectionRequired') {
enquirer.ask([{
type: 'list',
message: 'Which team should be updated?',
choices: e.error.data.teams
}]).then(results => module.exports.run(args, results));
