SCST Downloads
The latest stable version of SCST is 3.3. The latest updates for that version are available on the 3.3.x branch in the SVN repository.
Debian packages can be built by running "make dpkg". RPMs can be built by running "make RPM".
As a complete SCST-based system you can try Enterprise Storage OS (ESOS).
There is also a well done user space port, which you can find here.
The latest development version of SCST is 3.4. You can download it as well as target drivers and user space utilities directly from the SCST SVN. You can access it using either web-based SVN repository viewer or using anonymous access:
svn checkout svn://svn.code.sf.net/p/scst/svn/trunk scst-trunk
Also you can find in the SCST SVN the latest updates for the stable branches. More information about accessing SVN repository may be found here. Or, alternatively, you can download it as a GNU tarball from here.
History of the pre-SVN SCST development is available in SCST CVS repository, which is accessible using web-based CVS repository viewer, or anonymous CVS access.
