SCST Downloads
The latest stable version of SCST is 3.6. Updates for that version are available on the 3.6.x branch in the Git repository.
Debian packages can be built by running "make dpkg". RPMs can be built by running "make RPM".
As a complete SCST-based system you can try Enterprise Storage OS (ESOS).
There is also a well done user space port, which you can find here.
The latest development version of SCST is 3.7. That version including target drivers and user space utilities can be downloaded directly from the SCST Git repository.
You can access it using either GitHub repository viewer or using 'git clone':
git clone https://github.com/SCST-project/scst.git
Also you can find in the SCST Git reposity the latest updates for the stable branches.
History of the pre-Git SCST development is available in SCST SVN repository, which is accessible using web-based SVN repository viewer, or using anonymous access:
svn checkout svn://svn.code.sf.net/p/scst/svn/trunk scst-trunk
