![[ICO]](/icons/blank.gif) | Name | Last modified | Size | Description |
![[PARENTDIR]](/icons/back.gif) | Parent Directory | | - | |
![[DIR]](/icons/folder.gif) | client-cognito-identity/ | 2024-09-24 22:14 | - | |
![[DIR]](/icons/folder.gif) | client-secrets-manager/ | 2024-09-24 22:15 | - | |
![[DIR]](/icons/folder.gif) | client-sso-oidc/ | 2024-09-24 22:15 | - | |
![[DIR]](/icons/folder.gif) | client-sso/ | 2024-09-24 22:15 | - | |
![[DIR]](/icons/folder.gif) | client-sts/ | 2024-09-24 22:15 | - | |
![[DIR]](/icons/bomb.gif) | core/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | credential-provider-cognito-identity/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | credential-provider-env/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | credential-provider-http/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | credential-provider-ini/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | credential-provider-node/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | credential-provider-process/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | credential-provider-sso/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | credential-provider-web-identity/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | credential-providers/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | middleware-host-header/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | middleware-logger/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | middleware-recursion-detection/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | middleware-user-agent/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | region-config-resolver/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | token-providers/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | types/ | 2024-09-24 22:16 | - | |
![[DIR]](/icons/folder.gif) | util-endpoints/ | 2024-09-24 22:17 | - | |
![[DIR]](/icons/folder.gif) | util-locate-window/ | 2024-09-24 22:17 | - | |
![[DIR]](/icons/folder.gif) | util-user-agent-browser/ | 2024-09-24 22:17 | - | |
![[DIR]](/icons/folder.gif) | util-user-agent-node/ | 2024-09-24 22:17 | - | |
