[console_scripts] easy_install = setuptools.command.easy_install:main easy_install-3.5 = setuptools.command.easy_install:main [distutils.commands] alias = setuptools.command.alias:alias bdist_egg = setuptools.command.bdist_egg:bdist_egg bdist_rpm = setuptools.command.bdist_rpm:bdist_rpm bdist_wininst = setuptools.command.bdist_wininst:bdist_wininst build_ext = setuptools.command.build_ext:build_ext build_py = setuptools.command.build_py:build_py develop = setuptools.command.develop:develop easy_install = setuptools.command.easy_install:easy_install egg_info = setuptools.command.egg_info:egg_info install = setuptools.command.install:install install_egg_info = setuptools.command.install_egg_info:install_egg_info install_lib = setuptools.command.install_lib:install_lib install_scripts = setuptools.command.install_scripts:install_scripts register = setuptools.command.register:register rotate = setuptools.command.rotate:rotate saveopts = setuptools.command.saveopts:saveopts sdist = setuptools.command.sdist:sdist setopt = setuptools.command.setopt:setopt test = setuptools.command.test:test upload = setuptools.command.upload:upload upload_docs = setuptools.command.upload_docs:upload_docs [distutils.setup_keywords] convert_2to3_doctests = setuptools.dist:assert_string_list dependency_links = setuptools.dist:assert_string_list eager_resources = setuptools.dist:assert_string_list entry_points = setuptools.dist:check_entry_points exclude_package_data = setuptools.dist:check_package_data extras_require = setuptools.dist:check_extras include_package_data = setuptools.dist:assert_bool install_requires = setuptools.dist:check_requirements namespace_packages = setuptools.dist:check_nsp package_data = setuptools.dist:check_package_data packages = setuptools.dist:check_packages python_requires = setuptools.dist:check_specifier setup_requires = setuptools.dist:check_requirements test_loader = setuptools.dist:check_importable test_runner = setuptools.dist:check_importable test_suite = setuptools.dist:check_test_suite tests_require = setuptools.dist:check_requirements use_2to3 = setuptools.dist:assert_bool use_2to3_exclude_fixers = setuptools.dist:assert_string_list use_2to3_fixers = setuptools.dist:assert_string_list zip_safe = setuptools.dist:assert_bool [egg_info.writers] PKG-INFO = setuptools.command.egg_info:write_pkg_info dependency_links.txt = setuptools.command.egg_info:overwrite_arg depends.txt = setuptools.command.egg_info:warn_depends_obsolete eager_resources.txt = setuptools.command.egg_info:overwrite_arg entry_points.txt = setuptools.command.egg_info:write_entries namespace_packages.txt = setuptools.command.egg_info:overwrite_arg requires.txt = setuptools.command.egg_info:write_requirements top_level.txt = setuptools.command.egg_info:write_toplevel_names [setuptools.installation] eggsecutable = setuptools.command.easy_install:bootstrap
